Hello, i'm using Autocad 2015 LT now for a few weeks and i have a problem with the Trim/Extend function.
When i was using Autocad 2014 LT, i could trim en extend lines/polylines etc. with a Region, this is not working in Autocad 2015 LT anymore.
Please let me know if there is a variable wich i have to change or something els, its very annoying.
Gr. Sander.
Steven, in the attachment a DWG, if loaded in Autocad 2014 LT ther is no problem trimming or extending, if loaded in Autocad 2015 LT, i'm not able to extend or trim to the Region.
Edgemode and Projmode can have an effect on the trim command, when things have a different elevation, which isn't the cause in your drawing, maybe someone else with 2015 can check it, do you get an error message in the command line telling you why the object can't be trimmed?
I was able to trim using your region but only after I moved everything closer to 0,0,0. I can't explain why that is.
BTW...when it does fail AutoCAD reports back saying...."Does not intersect with the cutting edge."
I've tried both of them, Edgemode had different value then the one in 2014, but there was no result in trimming or extending.
It's like autocad sees the Region as a block or polyline, except when it comes to trim/extend, wich is no problem with the same drawing in Autocad 2014 LT.
Yes, i've red your response, sorry i'm also busy working.
It works indeed, i'm curious why, but glad it works now.
(I've got the same answer on a other forum just now)
Thanks you all.
