Since I've installed Revit LT Suite (I'm only using ACAD LT while I transition), whenever I either attempt to spellcheck or type a first command in my session, I get the following warning "Unable to find main dictionary. Could not start speller." I've tried DICTMAIN to no avail. I have "None Available" under the search path for Main Dictionary with all options greyed out. I've tried to locate the .dct file on the install DVD's, also with no luck. Has anyone encounteted this and, maybe, solved it?
Dean,
I created a blank text document, renamed it maindict.dct and put it in the support directory. I tried restarting ACAD a few times, but there's no ability to set it even as a custom dictionary (everything is disables/grey. I also tried DICT command and set it to the same name. DO you know where the file is supposed to go?
