Hello.
I am recently facing some problems in Autcad lt. 2012. I want to save a DWG as a DXF. More precisly i want to save it in the R12/LT2 dxf format.
But it does not work anymore. The error message basically says "Can not save drawing as /******.dxf. Drawing is saved as /******.tmp" [translated from german ].
It had worked fine for the last two years, but now i can not find a solution for the problem.
Sincerly Lukas
Welcome to the Autodesk Forums!
First thought would be to shut down and restart CAD.
Second would be to do a cold restart of your Computer then restart CAD.
Thirdly - If that does not clear the issue have you run a Registry Cleaner on your system recently?
Or changed the computer some other way? Window update? New program?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hello.
Thanks for the quick answers.
@ pendean:
@ Charles_Shade
Further information:
The operating system is Windows8 Home Premium (64 Bit).
The save-as-dxf routine is not working for all the DXF-formates, not only the R12/LT2 format.
I also tried to turn off the anti-virus-program i am running while saving the drawing. It did not work out.
Sincerly
Do you have the disk and can do a repair install?
Sorry guys,
i messed up the numbers and gave you a wrong information.
My operationg system is Windows 7 Home Premium (64bit). I hope this version is supported. To be honest I did not check that, back when i was buying Autcoad lt.
@Charles_Shade
I have the CD an tried the repair install. It did not fix the problem.
@Pendean
Running Autocad lt as an administrator does not fix the problem. I have no idea why Windows would restrict the action. Any clues?
Sincerly
HI! Think i've fixed the problem!!!
I had the same problem trying to save R12 LT2 and DXF files. Last week the program did work, but this week i cant save the file. Strange. The error message shows "Can not save drawing as /******.dxf. Drawing is saved as /******.tmp".
I solved the problem by saving the file in another path that does not contain accents or strange characters. Not the file name, THE FILE PATH must only contain A-Z characters. NOT ACCENTS (sin tildes la ruta!)
