This problem has cropped up in the last few months. It only happens intermittently.
Typically I select Trim, or Extend command, right click to select All rather than a specific object, then selcet the objects to be trimmed or extended.
Sometimes though, the All command is not activated and I have to select the object to be trimmed or extended to, then select the objects to trim, etc. Then the next time I right click for All it works.
It's very frustrating not knowing what is going to happen. Does anyone have an idea as to why this is happening?
Since <All> is the default option, you can also activate it with Enter or Space (instead of right-click). Does that fix the inconsistency?
Yes, that also works. It remains to be seen if it works consistantly. Thanks.
When you can not use all option in Trim and Extend commands - does All option doesn't activated at all, or you can see something like: "Edge is perpendicular to UCS XY plane." at the command prompt?
Maxim
I just use the crossing boundary box.
Howard Walker
I appreciate the workaround/alternative suggestions, but what I am concerned about is why this has started happening? Is it a glitch? LT 13 on my machine has lots of little twitches and stutters that I have never encounted before. And I date back to Autocad 10!
So is this a symptom of something more onimous about to start happening? Should I worry about fixing a small injury now to prevent a serious infection in the future?
Hmm, my high school band director used to say "it's never the instrument that goes wrong, it's usually the player."
So this is still happening. And the right click is activating the command. Select all is the default on the command line but when I right click to accept that the computer keeps asking for me to select an object to trim or extend to. the command line says Extend [Fence] [Edge] etc as usual but when I select the line nothing extends.
I also tried typing in all, every object highlighted, then when I right clicked and selected the line to extend again, nothing happens.So it doesnt seem to be an issue with the mouse.
If I select an object to extend to, right click, select the line to extend, it all works normally.
Hello
Sometimes the right mouse button is very tired !?
So even with a correct timing/delay, strange problem can appears ...
A stupid idea :
Could you test again with a beautiful new mouse ?
or a nice one from a friend ?
Bye, Pat
Patrice BRAUD
Ok, so I tried a different mouse and that is not the problem. And today Trim, Extend, and Fillet have stopped working completly. No method I have tried works. I rebooted, checked for updates, rebooted. No change. It' is not the equipment!
