Thanks Grant.
I have this folder and it contains three files : one xml file, one html file
and one dat file.
If no further info posted I'll try this. I'd have thought there'd be a
simple procedure to follow described somewhere in the documentation but if
there is I haven't found it yet!
Mike
wrote in message news:5100995@discussion.autodesk.com...
I've transferred once before, and this worked.
I run Win 2000, which is very similar to XP. There are 4 registration files
in folder C:\Documents and Settings\All Users\Application
Data\Autodesk\AutoCAD LT 2004\R9.0\ADLM
When you install AutoCAD, you have the option to register later. You can
then copy the same 4 files into the same folder in your new PC. If it's not
there, just use new folders to make the same filepath.
This probably isn't the 'proper' way to do it, but it worked for me a year
ago without any problems.
Grant
