In my company, they have just upgraded the old version of Autocad LT 2004 to the new 2013 and we have created menu to make our job easy. I have try to transfer the menu file .mnc to 2013 but it's not working or I don't do it the right way.
Could anybody help me with this issue ? Thanks.
Benjamin
Its a bit more complex than adding additional lines to the MNS. I would *strongly* recommend researching the CUIx system prior to attempting this. While its unlikely you will damage anything its possible to do things that will make life much more difficult down the road.
In short, the usual process would be be to convert the old MNS to a CUIx file to be partially loaded to either the Main or Enterprise CUIx. In some cases you may actually want that old MNS content to be part of the Enterprise. Either way, once the elements are in the CUIx editor (either directly from the Enterprise or Main, or as part of a partially loaded one) you add those to a workspace. The active workspace determines which of these elements are shown.
