I'm trying to insert a block, wich contains 2 nested blocks:
1 dynamic block
1 annotive block which has a scale 1:200 with an attribute.
when i'm inserting it trough the toolpalette, and my annoscale is 1:100, the annotive block is converted to the annotive scale 1:100, instead of the 1:200 wich it originally is.
i can't set the annotationscale in the toolpallete, exept when i use macro's.
but this also has a drawback.
when i'm inserting the block with a macro, i have to insert a complete drawing wich contains only this one block.This block contains dynamic parameters (i can't add dynamic parameters outside of the blockeditor)
When this block (dwg) is inserted, i explode the block so it becomes the dynamic block again. but the block cannot be redefined, because the actual inserted block is a dwg file.
can anyone help me or is it a drawback of the use of the toolpalette and dynamic / annotive blocks?
thanx in advanced for your replies.
Solved by AcadAdamLT. Go to Solution.
The default here for = is No in answer to the redefine. Does your system default to Yes?
Expanding on the thread for others:
Also the -I function only finds Blocks in the Folders that are included in the Support File Search Path.
I have Blocks in a bit of a tree (Elevation, Plan, Section, etc...) so I would need to include each of these paths to use this.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
