AutoCAD LT Forum
Tool Palettes
2 REPLIES 2
millerew17
437 Views, 2 Replies
Tool Palettes
In 2013 LT..... How do you copy or transfer revised blocks to your tool palettes in other dwgs? I thought once blocks were revised in BEDIT, and saved they would be transfered to all dwgs. I have 3 other dwgs with some of the same blocks but those tool palettes have the original blocks in them.
2 REPLIES 2
pendean
in reply to: millerew17
BEDIT edits the block in the one drawing file you are in. You are thinking of XREFs instead: do you need to use XREFs for this situation?
PLUS Toolpalettes are static: like having two copies of a book, one on the shelf (aka Toolpalette) and one in your hand. remove or add pages to the one i your hand will not change the book on the shelf.
So... find the original source of the Toolpalette block (you have to edit the source), then move it to the TP to replace the one you no longer want. You need to maintain one source for all your blocks: they want you want to do it will create one heck of a mess whenever you need to fix things again.
Now back to your other question: LT does not have a block replace feature, so you are going to have a hard time doing what you want easily. Your choices in LT are:
1. Rename the old block and INSERT the new block in it's place at every location.
2. WBLOCK the revised block out to a central location with the same exact name then use INSERT command to replace the one you have in each file.
Good luck.
millerew17
in reply to: pendean
I understand...Thanks!
”Boost
