I have tried to search this subject with no luck before I posted this. We are using LT 2011 and 2012.
My company has cad standards is for everything to be drawn on a snap. All of our blocks are designed with that in mind. Now we want to start using tool palettes to insert our blocks. When we have tested using tool palettes, with the blocks we have made, sometimes the block will drag into the drawing to snap and sometimes it wont. What are we missing? I have also read online that tool palettes blocks will not go to snap at all. We have seen it work (sometimes).
Scott
Solved by pendean. Go to Solution.
Have you tried adding a Basepoint Parameter to the Blocks with the Block Editor?
This would force the now Dynamic Block to insert at the point the Parameter has been assigned.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
No Charels, sorry but that did not work. I just don't understand why Autodesk would make such a great function like Tool Paletts and then not allow the item to be dragged in to some type of snap. Since we draw on a snap and grid, setting up our blocks in Tool Palettes would be a waste of time. DOES ANYONE USE TOOL PALETTES?
I'm not sure what your issue is: can you elaborate? I can click on a block in any pallete in 2011/2012/2013 and it activates the INSERT command and I can snap to any point (with SNAP on).
Are you perhaps clicking and dragging a block from the palette? that does not work the same way as noted above and sounds more like what you describe.
Dean, Thank you so much. You were right. I was "dragging" the block from the palette. But when I "click" the block, it does insert to snap in the drawings. Again, thank you for setting me straight. As normal, my problems are "operator error" based. Scott
