That will only work for LT2005: Windows must have that as the default LT
running on your system. Run it, then make sure dwg files default to it when
double-clicked in Windows Explorer, then try the hotfix.
There is no cure for 2002.
I understand using the free converter from Autodesk and saving down to R2000
or R14 is supposed to be more friendly for older versions of AutoCAD, but
I've not tested it.
I also understand round-tripping files to R12DXF fixes the problem too: also
not tested by me, so I can't confirm this.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
