The text inside the viewports in one drawing in paper space shows thickened when zoomed in and is hard to read, and this only happens in one drawing.
What is the setting to change this?
Thanks.
Solved by pendean. Go to Solution.
Solved by octavio2. Go to Solution.
Hello
Just an idea :
Please check Text Styles and the width factor ...
Width = 1 (Please)
Bye, Pat
Patrice BRAUD
If the above idea does not work, select the text objects, start PROPERTIES command, and ensure the Z settings is zero (actually type in 0, don't just assume it is if that's all AutoCAD shows you as your precisions settings may be forcing it to round up).
I found what it was:
Options/User Preferences/Lineweight settings/Apply Lineweight was turned on, and I turned it off.
Thanks to all who responded.
Great: fix this permanently by setting all of your objects to either LWEIGHT=0 or BYLAYER and control them in the LAYER command. Sometimes trying to remember to turn something off when a deadline is looming can waste a lot of time: set them they way you need them all the time instead.
