All the old version of cad were set so when you pressed the up arrow while drawing a line you would get the last thing you typed.
so if you where drawing a shape and you pressed up you would get the last dimension you typed and you could draw the same shap again without re typing the same dimensions.
With 2006lt when you press up while drawing a line you get the last coordinates you used. Is there a way to change this at all.
Thanks for any help you can provide.
