Hi
I have just found out that LT is not capable of doing the text2mtext change. Oh Misery
Does any one know of a short-cut?
Andrew
Solved by pendean. Go to Solution.
Solved by Charles_Shade. Go to Solution.
Nope. Create a new MText object, then copy and paste the contents of your DText objects into it one by one...
Trying to score points there Modman?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
AutoCAD LT 2013: Is there still not a macro or something that could be created or added or appendex in some way to allow the Text to be converted to MText?
How come that Autodesk has been ignoring this, in these times of AutoCAd LT 2013?
Has this ever been resolved by Autodesk??? Its a comand thats used quite often. Can the express tools not be reconfigured to be loaded into LT???
The command is not available in LT. There is no new news concerning the feature.
You cannot run Express Tools in LT.
ok.. thanks. Really to bad tho, it was/is a useful command as are most of the Express Tools. I'll just have to adapt to doing this differently
