Hi
I am trying to do something that i do not think can be done on CAD so just to check if it can be done im on here.
What it is i would like to do is write a text script on my drawing that only pops up as you hover over it.
Here is an example: I have a drawing of a pipe in AutoCAD LT and i would like to add text scripts of the pipes details i.e thickness or make or what type of material but i would only like it to apear when clicked on just like the photo's on google earth.
if any body can help me with this it would be great!
many thanks
Johnny
No not in LT
anyway if i reight you shoud use P & ID
Look into BLOCKS, ATTRIBUTES, and the QUICKPROPERTIES PALETTE.
What version of LT do you have BTW?
(if ("mysolution"=answer) then (click "Accept As Solution"))
"AutoCAD LT and i would like to add text scripts of the pipes details i.e thickness or make or what type"
on a Line ?
no way in LT
Granted there is no automatic way of adding those properties, but adding properties (hidden attributes) to blocks can get the OP where he wants to be if he already has LT.
Now if OP's looking at whether or not they should buy LT for this, then I would agree with you; they should look at other products made specifically for their line of work.
>>>... pipes details i.e thickness or make or what type of material...<<<
If I understood your requirement... You might be able to get closer to what you desire with HYPERLINK command (either a a link to a document or website, or a simple description list, or both. Help yourself.
thanks for the replies.
could anyone tell me which version of AutoCAD would this work on.
also what version of CAD should i be using because as far as i am aware for utilities (water, gas, electric so on) we should be using LT.
may thanks again
Since your exact need is not quite well defined yet, LT may be sufficient.
AutoCAD MEP (buildings) or AutoCAD Civil 3D (infrastructure) may be the other AutoCAD variants you seek: download the trials and see what fits your need after reading the program descriptions.
You can also look into Dynamic Blocks, there's alot you can archieve with dynamic blocks.
i dont know , what you are talk about , he talks about Piping , so scho me exampel how this shoud work
without PnID ? That is how it works all other are Playing around in Kindergarten or show me how you do it.
I like to learn more ....
cw
Send those files along as well (be careful about pathing issues): or better yet, centrally locate the files for both of you to access (server, or webdav server or website/ftp site a s link etc.).
Remember, a hyperlink is static so it's up to you to find common ground for everyone to be able to use them.
