AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
text edit and delete not working
3 REPLIES 3
1435 Views, 3 Replies
When I double-click on a text item, AutoCAD used to go to text edit mode, without entering the TEDIT command.  This quit working - now I have to enter TEDIT.
Also, when I select items and hit the Delete key, nothing happens.  The selected items used to get deleted.
I tried going to the Windows Start menu and resetting all of the settings to the defaults - this didn't work.
I also tried re-installing AutoCAD from my original disk, and that didn't work either.
Any suggestions?
TC
3 REPLIES 3
pendean
PICKFIRST variable, explore it in HELP and turn it back on.
Thank You/!!
gbeekman
Thank you.  Life saver.  Never knew about this.  Thank you.  Still don't understand it's use but now I can doubleclick text to edit again after a couple months of frustration
”Boost
