I have a very annoying problem that when I move text in any way other than orthagonolly the text written in that object becomes thicker and clumsier. Any clues?
Solved by heinsite. Go to Solution.
Solved by pendean. Go to Solution.
More than likely you already have many SHX text font files on your system. Simply go to the Text Styles manager (STYLES at the command line) and look thru the Fonts list. Any that you see there with the .shx file type are the ones you're looking for. Examples include romans, romant, and many others. If it doesn't have a TT symbol in front of it, it's probably an SHX.
Dave.
