AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
TEXT DIFFERENT THICKNESS ON SAME LAYER
18 REPLIES 18
Message 1 of 19
jeng
7456 Views, 18 Replies
ANYONE.......... please help. why is text on same layer and printing and showing different line thickness and how do i get rid of this problem asap..we have a presentation by noon.and boss is not happy. help..... we have matched properties and every thing - now it its on the same layer but its is still showing different thicknesses.help
18 REPLIES 18
Message 2 of 19
jholt
in reply to: jeng
Sorry, no quick fix here, but...
Is it always the same text that prints wrong? It could be your plotter, plotter settings, text style, CTB, PC3, etc. The problem could be one or a combination of these.
Can you give more infomation?
jeff <><
Message 3 of 19
jeng
in reply to: jeng
jholt...thank you for your reply..ok here goes..... properties for text....same font same thickness...same layer same everything....
when we plot we just did its line weight set..and even did no line weights and it still did the same thing...
Message 4 of 19
jholt
in reply to: jeng
What do you mean by same "thickness"? This generally refers to a Z axis dimension, not a line weight.
Is the text single line or multiline. If multiline, you can change the color of just part of it. It might look the same as the rest, but BE different.
jeff <><
Message 5 of 19
jeng
in reply to: jeng
Ok...so how do you check to see if it is a multi line...in properties under general theres thickness....first it said one was 1" then the other said 7 feet...!!!!!!! now both say 7' but they are showing different thickness.... one looks normal the other looks bold... and no bold is not activated..(hahahaha)
sorry for being a pain..iam ready to throw the computer...
the girl that did this copied and pasted from and old drawing could this be a problem????
Message 6 of 19
in reply to: jeng
Could it be you have an LWEIGHT setting assigned to one and not the other? Set both to DEFAULT. Do you plot with CTB or STB? If STB, make sure the correct plot style setting is assigned. TTF fonts don't have such issues, too late to switch? -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Message 7 of 19
jeng
in reply to: jeng
Thank you both for your help....- ctb says plot at specified line weight..which is at default... but still doing it.....i don't know:-( even if we do with non..it still does it...iam at a lost...tif i don't see anything...so i don't think it is that....any other last min suggestions would be great... but iam running out of time...but thank you once again for your time
Message 8 of 19
in reply to: jeng
In your rush to 'fix' it, you are ignoring everything else we are all posting. LWEIGHT is a command and a setting, look up usage in HELP then try suggested fix in my post. Also consider a switch to TTF for your 7foot high text, it would look better than SHX. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Message 9 of 19
in reply to: jeng
If it is MTEXT, go into the editor (double click the text), highlight the text and reselect the style that it should be. This should reset any style overrides that may have been set. -- Daniel J. Altamura, R.A. Altamura Architectural Consulting and SoftWorx, Autodesk Authorized Developer -------------------------------------------------------------------- "jeng" wrote in message news:12424297.1110901308437.JavaMail.jive@jiveforum2.autodesk.com... > ANYONE.......... please help. why is text on same layer and printing and > showing different line thickness and how do i get rid of this problem > asap..we have a presentation by noon.and boss is not happy. help..... we > have matched properties and every thing - now it its on the same layer but > its is still showing different thicknesses.help
Message 10 of 19
rockhopperst4
in reply to: jeng
We are having the same issue. If i create two identical boxes of text then move one of them it often changes slightly. It goes slightly bolder. the same apllies to door and window tags (In ADT) and dimension strings. I can fix the text by going into properties, setting the z value to 10 then setting it back to 0. I have to do that for each one. Can't fix dimensions like that though, the only way appears to be to do them again.
Message 11 of 19
in reply to: jeng
ADT and full AutoCAD, but not LT, have OSNAPZ variable to control the
problem.
Dean Saadallah
http://LTisACAD.blogspot.com
Message 12 of 19
I have the same problem often. Can even copy some text and edit the wording and it will have a slightly bolder look to it. Just enough for it to look horrible. On the atthachment, all the larger text is exactly the same in every way. What is up with this
Message 13 of 19
Post your drawing if you can or WBLOCK a piece of it that has the issue and post
Usually Text varying in thickness is due to the Text being at an elevation; i.e. something other than Z=0
In LT you can Flatten it using this Macro placed on a button:
-Flatten Z coordinate:
^C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99;
Or is the text coming from another computer and maybe the Fonts are not identical?
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Message 14 of 19
rust.uzakov
in reply to: Charles_Shade
Double Click your text
-> the button calls " Clear"
after that click on the small triangle and select -> Remove Character Formating
Message 15 of 19
Emmsleys
in reply to: rust.uzakov
Thanks for sharing your suggestions. This thread is a little old so I don't think the OP will be back. But I'm sure other users will find it helpful.
Smiley Happy
Sarah Emmsley
Technical Support Specialist
Message 16 of 19
HQGL01
in reply to: jeng
I work with Civil 3D and this problem occurs on this program when texts are not at the same Z. So texts that are higher appear bolder and lower texts appear thinner.
Maybe you could check this out.
Other than that I wouldn't know.
Cheers.
Message 17 of 19
saya.rian
in reply to: rockhopperst4
yes, this problem is solve. thanks
properties in text set z to 0
in my case z is -0.1xx
Message 18 of 19
dsweetMCA8J
in reply to: jeng
Try going into the text block and selecting each portion of text.  Make sure that in the text editor area above that everything is set to "by layer"
Message 19 of 19
notsew93
in reply to: jeng
Thread is quite old, but I wanted to mention a solution for the same issue that happened to me:
Each of my mtext/text boxes had all the same properties, same style same color same everything, and I knew this was true not only because I had checked the properties box but also because I had just gotten done copying each of these mtext items with an Array command! How are they printing different?!
It turned out that I had accidentally set the Z rise of the array command to 1 units instead of 0 units, so each of the text items were a different height off the paper. (And AutoCAD was making the higher ones slightly bolder - I suppose it was trying to give them the illusion of being closer to my face.)
Normally one would have never noticed that mistake in a 2-D drafting setup, but when I had exhausted looking for other solutions and I was checking the properties of them again, down towards the bottom it said "Position Z = *Varies*". A-ha!
”Boost
