AutoCAD LT Forum
Temporary Dimension
6 REPLIES 6
louise.capelleburny
1521 Views, 6 Replies
Temporary Dimension
Before upgrading to AutoCAD LT 2014, I was able to select a grip on a line or a an object & the dimensions would temporarily pop up without me having to type in a command or using the measuring tool. Now when I do the same thing it offers me: Stretch/Lengthen or nothing. I have been trying to find a way to do get back the time-saving measuring feature.
Help please! Thanks.
6 REPLIES 6
Try pressing the F12 key and see if thats what you want.
Turn on DYNMODE or click on the DYN icon at the bottom of the AutoCAD/LT2014 program window.
Thanks, but I don't see a change.
I don't see the icon you are speaking of.
When I type in DYNMODE it asks me to set a new value.
Is your DYNMODE SET TO 3?
Thank you, sthompson1021 & pendean!
It has been a horrible 50+ hours without this feature.
Fome some reason the DYNMODE was set to -1.
Problem solved. Smooth sailing from now on :). L
”Boost
