Hi, I haven't address this forum before, I have a desktop that I have AutoCAD LT (2008) on, and I want to take it off and put it on a laptop so I can take it with me and use when I need.
I think I need to delete it off the desktop and install the disk with the autocad lt 2008. I think that's all I really have to do, but I would like some advice and make sure that if I deleted off ,I wouldn't be making a mistake.
Solved by may.anne.ruiz. Go to Solution.
Let me share my issue. My old PC decided to go to lunch and not come back, so I bought a new one -- took the plunge and got a 64-bit version. When I went to activate my software, I got blank white dialog boxes -- one with two radio buttons and that was all. Being on subscription, I put in a technical request (including the fact I can't access the old PC to export the license), and then followed all of the suggestions that were applicable, from their article. I rolled back to IE8 and it didn't work. I changed all of the internet permissions to allow Active-X and javascripts, and that didn't work. I checked the properties of the white boxes, put their address info into the address bar, and that sort-of worked (but not really) after I also pasted the one line of text into each RT file they directed me to. Still, it only ended up taking me round-trip right back to either the same white boxes or the Try/Activate screen (which itself would lead back to the white boxes).
After some back and forth with some autodesk individuals, I was told they did indeed show my product(s) as being activated for my new computer, but the file that is supposed to contain my activation code is just not on my computer, and my software still shows it is in the trial phase instead of activated. and that is where I stand with that whole mess right now. Has anyone had the same issues? Have you found a resolution I might not have tried yet?
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Thanks but those two were the ones autodesk sent me to and I tried it all. Right now they want me to call for a code and enter it maually, so I'll let y'all know if it worked or not...
Update. Called the 1-800 number, got a new code, and all appears to be working 🙂
Am now celebrating with ribs from Liborio's in Tampa 😉
