Sven, the drawing has become corrupted, possibly by the blocks you're
inserting into it. Try the recover command or insert the problem drawing
into a new drawing.
Another possibility is that the program itself is unstable. If there is
a possibility that you had a virus scanner running in memory during
setup, it could have prevented some of the support files for AutoCAD
from registering correctly. Try uninstalling AutoCAD 2000 and then
remove the AutoCAD main folder and then Autodesk Shared folder and end
process on the antivirus program(s) and also other non-essential
processes before running setup.
sven wrote:
> Hi
> I habe following problem, work under WinNT4 "Serv.Pack6"
> AutoCad works but if i copy and insert some details my programm closed
> by himself without a errormsg. If i consult the error log, i can find
> nothing, same as i look in eventviewr.
> Today my programm gives me a error msg "Systemerror: Unhandled Access
> Violation Writing 0x0019 Exception at 7800d0c3h
> Could anyone help me ??
> please write me back
> sven durgiai
Bob Felton
Autodesk Product Support, USA
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
