Hi guys,
I'm facing a problem that each time after I did Regen or Zoom, the system halted and then recovered only after several minutes. I guess maybe it is related to special drawings, because it only happened when working with the drawings which was transferred from an .iges 3D drawing. Anyway, it is a really a pain for me.
Did anyone meet the same case by accident before? Could you share with me the real cause and solutions?
Thanks a lot!
-Ken @AutoCAD LT 2010
Solved by Charles_Shade. Go to Solution.
Solved by braudpat. Go to Solution.
Hello
Just a few ideas :
1) Have you purged theses DWGs ?
Command: PURGE
2) Have you tried to open these DWGs in Recover mode ?
Command: RECOVER
3) Maybe you could install the SP 2 for ACAD LT 2010 :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15073321&linkID=9240818
Bye, Pat
Patrice BRAUD
Hi Pat,
Just tried and it has been proved that it does not work with "PURGE", and it did work with "RECOVER", however, some line and arc segments were lost afterwards. At the end, I installed the SP 2 and it works perfectly now without any side affects. By the way, do you know what was updated in SP 2 by Autodesk?
Thanks a lot!
-Ken
Hey Charles
I will give you a "pseudo" Kudos as the "ReadMe Manager" ...
Bye, Pat
Patrice BRAUD
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hi Pat and Charles,
Thanks very much for your help!
Hope to have more communications with you in the future.
-Ken
