I have recently upgraded to LT 2012 from LT 2009. In 2009 I was able to double click on text in paperspace to edit it. On occassion it would click through to Modelspace but not usually. Now in 2012 it seems to click to modelspace every time. I searched online and found the switchspace variable but it does not seem to be a valid command in LT 2012. Did the name change? Is there another way to stop the double click to change into a modelspace viewport?
You should be able to do this without clicking thru. Are you able to simply select the text and right click edit it? I had no trouble doing what you described with either single or multi line text.
Dave.
I have right click set to repeat last command. When I left click the text once it selects fine. When I double left click the text it pops into modelspace with textedit command open and looking to select text.
Oooo, that's really not a good idea, sorry to say. By setting your right click to repeat the last command you've inadvertently disabled a LOT of functionality in AutoCAD. By default you get access to many menus and functions with a right click... but you've lost them, it isn't worth the "cost", and may somehow be related to your troubles. There are other ways to get the last command. You can get it by pressing the spacebar or up arrow. I suggest you reset things back to the default and see if that affects the click thru problem. Even if it doesn't you'll be better off.
Dave.
This is kind of a first step. If it fixes the problem, you're done. Otherwise we'll have to continue looking.
For you it's time to move on to the new way of doing things. There's too much in the right click functionality now to give it up. What you think you'd gained you really lose more.
Dave.
I turned all the menus back on and it is still switching into the viewport instead of opening up the texteditor. I do see the texteditor in the menu but I am still quicker typing in a shortcut than using a menu. For me personally I have always found the menu systems slow me down. I have tried at a few different times and never found the additional features to be useful or speedier than my old fashioned ways.
It's time for you to go into the CUI then and look at what the Double Click Action macro is for Text and MText then. Text should look like the attached. MText should be ^C^C_mtedit. If the macro for these is blank, fix them and see if that solves the problem.
Dave.
Have you changed anything else on your system? The CUI mods might not fix this either, even if those double click actions were blanked. You might want to run a Repair of your installation if nothing else works. So far I haven't found any system variables that might change this.
Dave.
Have you tried to type the edit command and then select your text?
"ed"
space or enter or right click
select object
What size is your APBOX? AUTOSNAP variable setting? Zoomed out too far, does zooming in fix the problem? PICKFIRST turned on? Did you buy a new mouse? install new mouse drivers?
Upsize your screen with the upgrade? Window resolution higher?
My guess is you are missing the text entirely, so you need to find out why (we can't remotely help with it, only suggest things to try). There is no difference between 2012 and 2009, nothing changed. I can double-click on text over viewports all day long and never click through a viewport unless I miss.
