I know there's some smart guys reading these boards so hopefully one of you
can help me out 🙂
I'm having trouble with strange responses from LT when entering commands via
the keyboard.
For expample, I want to draw a line, I type "L" then hit the space bar. If I
do this too quickly I get another "L" appear on the comamnd line in the next
prompt for the line command e.g
LINE Specify first point: L
I have to delete the "L" before i can click my first point. It also happens
if I use ENTER instead of Space bar. If I type slower this doesn't occur. OK
I can probably slow myself down and live with this, but it's still annoying,
esp. considering I didn't have any problems with 2005 which I was using
previously.
Tried with a few other typed commands and same problem only seemed to happen
when typing "D" (for DTEXT).
But then it gets worse 😞
So I eventually manage to get my LINE command started ok and I click for
first point, then I want to snap PERP to an existing object.
So I type "PER" but for some reason I get "PRE" on command line. Now I know
my typing isn't the greatest but this occurs every time. Did a bit of
investigating and realised when I type the first "P" it doesn't appear on
the command line straight away. If I move the mouse then it does. Or if I
continue typing PER it does, but because of the delay I think the R is
appearing on command line first. Very weird.
Tried with a few other snaps but same problem only happened when trying to
type "E" for "ENDPOINT"
"P" and "E" both work fine on a clean command prompt to start a new command.
This is all with dynamic mode turned off btw as I couldnt really get to
grips with that feature, but I tried it with it on and got same results.
I also opened a Word window and tried replicating the problem by typing the
same characters but was all ok there.
And put fresh batteries in wireless keyboard in case it was that 😉
If it helps I'm running LT2006 on WinXP Pro SP2, 2.66Ghz P4, 512MB RAM,
128MB ATI Radeon 9800 vid card.
TIA
Greg
