A specific file all the time every time? Or a random file that you decide on during Startup? (Would a Script allow for that?)
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Set STARTUP variable to one.
Save this magic file as a template: when you start AutoCAD, the pop-up appears (because of the setting above), then you select whatever you want, when you want it.
