AutoCAD LT Forum
Stacked fraction settings
4 REPLIES 4
2937 Views, 4 Replies
Is there a way to set fractions to be stacked diagonally, permanently? I have this problem with regular mtext, not dimensioning (setting dimension fractions is ok.) I get things to look right, but when I re-open the file, all text fractions have become horizontally stacked. Any suggestions?
tyra
4 REPLIES 4
Start MTEXT, type in a fraction, highlight it then right click
on it, select properties, then make the settings you need, then click AUTOSTACK
button, pick the settings you like, especially Enable AutoStacking, and you are
ready to go.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Is
tyra
Still having the problem... (?) I have selected diagonally stacked at 80% in MTEXT, saved current settings, then enabled AutoStacking, and everything looks correct. However, the next time I open the file, all of my fractions in MTEXT are still showing up stacked horizontally at 70%, seemingly by some default I am not aware of. Have you ever encountered this? Also, once the dwg is re-opened, all of the incorrectly shown fractions require changing one by one. Is there not a global setting? Any more suggestions?
Ty, did you save the current settings as default while in the MTEXT
stack properties dialog? If you have and the settings are not being
preserved (they worked correctly here in a test of your issue) then try
this same procedure in a new drawing, started from scratch.
If they work correctly in the new drawing, the insert the problem
drawing into the known working drawing. If they don't work in a new
drawing, then it's possible that all the support files for AutoCAD LT
were not registered correctly during setup.
Try uninstalling LT and then end task on all programs running in the
background except Explorer and then reinstall. You maye have had a virus
scanner running in memory when you first set up LT that interfered with
the installer. Check with Ctrl+Alt+Del to see what's running in memory.
Bob Felton
Autodesk Product Support, USA
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
After typing a fraction, highlight it, right click, on the menu that appears left click on "Stack Properties", select "Style" ie. "Fraction (Diagonal)", click on "AutoStack... "Enable AutoStacking" ... "Convert it to a diagonal fraction" (or horizontal) ... and OK, (which returns you to the AutoStack Properties menu), click on "Defaults" and "Save Current Settings" ... and OK.
”Boost
