What I want to do is change multiple splines from "Show Control Vertices" to "Show Fit Points"
The problem is I have over 500 to do, and I cannot select each one individually and do it. It would do my head in.
Is there any way to change multiple splines all at once?
LT2012
Howard Walker
Solved by pendean. Go to Solution.
Nope tried that. It won't let me change multiples. It just sits on curve fit
Howard Walker
Yep just selected 241 splines and it won't let me change the method in properties
EDIT:
I've just had another look, and no wonder I can't change the method, it's greyed out. What setting do I need to change?
Howard Walker
I've attached a drawing.
All those plans were created from a PDF using Adobe Illustrator CS2.
I converted them all into blocks. Of the two leftmost plans the bottom one is still the block and the top one is exploded.
Howard Walker
You can right click and change them that way, but it;s still the same as using the arrow.
I don't see why illustrator change them to splines anyway as before it always did polylines / lines for everything.
Howard Walker
Changing them to plines would work, but I've found that slows the drawing down a bit.
Howard Walker
We're just people like you and we get stuck as well.
Howard Walker
Illustrator conversions are pure junk: I would not has responded had I known LOL
AutoCAD will let me change the Splines, LT will not. Not sure why.
Here is your file.
Try other PDF converters: start with the one from dotsoft.com
Cheers for that Dean. I hardly ever use Illustrator because the Clients' are usually good and send us Autocad versions of the plans when we ask. Some however don't and send us PDF copies of the Autocad drawings.
Howard Walker
