AutoCAD LT Forum
Some xref plotting nicely, some in same drawing - yucko
11 REPLIES 11
Message 1 of 12
draftinggreen
343 Views, 11 Replies
Hi, as indicated above drawing in the source file plots appropriately, two xrefs also plot as expected. One xref'd drawing  will not behave, no line weights reconized at all, at all.  Using ctb that works fine usually. I can't see any differences in plotting variables between source and xref. Moved the xref to a pspace window that works well with a similar drawing - no difference. So I assume there must be something about that xref... but what?
Any suggestions of areas to check would be massivley appreciated. I haven't had this kind of problem for years, I'm supposed to be a professional dammit.
Acadlt 2015 by the way.
11 REPLIES 11
Message 2 of 12
bob_mpc
in reply to: draftinggreen
As a first step, I'd suggest to try to RECOVER the xref.
Boris
AutoCad LT 2021.1.1
Message 3 of 12
Shawn_Niles
in reply to: bob_mpc
I'm checking to see if recovering the file helped? It does sound like an issue with just that one file. I'll put a link below to an article that discusses how to repair corrupt files:
http://knowledge.autodesk.com/article/AutoCAD-File-Corruption
Please let us know if the problem persists.
Shawn Niles
Message 4 of 12
draftinggreen
in reply to: Shawn_Niles
Hey Shawn, thanks for the suggestion, no luck however. It seems to be just the same. My next thought was to reconstruct the drawing but the list of steps in the corruption link are more thourough than I have used before, that will probably do it. I was hoping to avoid all that work and also understand what was causing it, which I probably won't know if I strip down the drawing and rebuild it.
Message 5 of 12
Shawn_Niles
Are you able to post the file here? I'm happy to take a look at it and see if anything stands out.
Shawn Niles
Message 6 of 12
draftinggreen
paste the dwg file here?
Message 7 of 12
Shawn_Niles
If it's not something that needs to be private, then yes, posting here is good as it gives many different people a chance to investigate. If it can't be shared publicly, let me know and I'll reach out to you directly.
Shawn Niles
Message 8 of 12
draftinggreen
Nope nothing secret.   Just a simple as-built building elevation.
Message 9 of 12
bob_mpc
Printed properly here.
Boris
AutoCad LT 2021.1.1
Message 10 of 12
pendean
You did not include your DZ4.CTB nor a container file where this "xref" causes issues described in your first post.
The file's paperspace tab where it opened is also set to plot to "adobe PDF": your issue may just be your Acrobat Reader settings and little else.
Message 11 of 12
bob_mpc
in reply to: pendean
Maybe I should give some more details:
I attached the drawing into new empty drawing and it plotted ok with "DWG to PDF" printer
Of course, in colour - the CTB is not available.
Is is possible that the layer in which the XREF is attached is set to "no-plot"? I have done this smart thing myself
Attached - the new drawing with the xref
Boris
AutoCad LT 2021.1.1
Message 12 of 12
Shawn_Niles
I did some cleanup to the original file you sent in. Could you try using this file and see if it gives you better results?
Shawn Niles
”Boost
