Anyone know if there is a way I can get NEAREST snap to work on the multileaders?
END and INT (where leader crosses other entities) work but cannot use NEAREST.
Can use NEAREST on normal leaders though.
Running AutoCAD LT 2013 on Win 7 Pro.
Solved by pendean. Go to Solution.
I occasionally like to have a leader with 2 arrow heads. I do this so by drawing a 2nd leader and would like to be able to snap NEAREST onto the line of the first. As it is I have to zoom in fairly close and manually position the 2nd leader over the first. Attached pic probably explains better than I can.
Maybe I'm over complicating and there's a simpler method for acheiving this?
Turn on and use Polar Tracking instead of Ortho, especially when creating and adding the angled leaders: they will always be the same angle and is quicker to do what you seek.
Adjust Polar's angle options to suit your needs, I find 15 is plenty for me.
Or, if it happens a lot, make a custom arrowhead with two arrows, and use that instead? Individual multileader segements can have different arrowheads.
