I am trying to PASTECLIP a portion of one drawing to another. The original drawing is the correct size however when it is put into the second drawing it shrinks exactly 3 times its size. I have checked the properties and they are the same. What am I missing?
UNITS in both files are set to what?
Are both drawings drawn at 1:1 scale?
UNITS are both set the exact same (mm)
Both drawings are set at 1:1 scale.
What are INSUNITS set to? Try "4" for mm.
Dave.
The original drawing is 684.925 and then it shrinks to 228.3 which makes it about 3.0001 times smaller. I think it is very strange.
Inside each file, match up all the settings when you type the command
-DWGUNITS (note there is a dash in the name of the command).
Ue the "good one" as your guide.
