I have downloaded the MrSid Viewer and when I open my drawing my sid files do not show up. When I open the xref box it says they are unreadable. Is there a way to have the sid files show up in LT 2007? Thanks.
They are only available in full AutoCAD with an Object Enabler installed: you will need to convert to a format supported by LT.
Dean's correct. The Autodesk Raster Design Object Enabler will not install in AutoCAD LT.
However, you can download a free viewer called IrFanView that can open your SID and save it as a TIFF or one of 21 other image formats that LT can attach.
