AutoCAD LT Forum
setting up
2 REPLIES 2
kedibeno
146 Views, 2 Replies
setting up
I just started using LT2002 today, and I am trying to setup my taskbars etc as I like. I am having two problems:
1) I am trying to change the object snap settings in the Tools/Drafting Settings/Object Snap box. When I press Okay, it gives me ERROR: Unable to set system variable: SNAPUNIT. Why?
2) Then under Views/Toolbars/Commands, some of the icons are not shown. It says "Close Window is there, and I can drag the button onto the taskbar and it works, but there is no picture associated with the command. How am I supposed to remember where I put which command?
Any help would be appreciated.
kedibeno
2 REPLIES 2
in reply to: kedibeno
1) Set SNAPUNIT, or SNAP to something other than the 0 setting
you have, and all will work well again. I know, nothing to do with it ....
2) Not all commands have a toolbar button image, so you need
to make one: right click on the button, and go for it. HELP in AutoCAD can
explain usage.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
kedibeno
kedibeno
Thanks Dean - Both worked.
kedibeno
”Boost
