AutoCAD LT Forum
Setting Osnap from a command button
4 REPLIES 4
252 Views, 4 Replies
I need to draw lines and want the OSNAP set to Perpendicular and Center. Is there a way to specify this in the Macro Associated with the button?
Example I have the line macro as such
^C^C_line
Need to add osnap before it
^C^C osnap; “Set Perp and cen” _line
TIA
4 REPLIES 4
Look up OSMODE in HELP, add the numbers up for your desired
Osnap or combinations, in your case, that would be 132
(128+4) ... .
^C^C_osmode;132;_line
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Oh Fantastic. Works Great, Saves a lot of time too 🙂
I'm having similar problems. When I have OSNAP on, using End, Mid, Centre, Intersection, Perp & Nearest. I'll type in a 'Bearing & Distance' (working in Surveying), then if the end of that line comes anywhere a previous line/endpoint, it automatically grabs the proposed endpoint, which therefore changes the 'B & D',
F3 button, toggle off running osnaps, F3 afterwards to re-engage.
Dean Saadallah
”Boost
