AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
SETENV in macro autocad LT 2013
8 REPLIES 8
Message 1 of 9
1153 Views, 8 Replies
I used the following marco in autocad LT 2010
^C^C_setenv;StartWithNumber;\_setenv;TextInFront;\
In autocad LT 2013 it stil works but i cant see what I'm doing.
The text StartWithNumber isn't shown in the command bar, but when I type in a value its works and
TextInFront is shown in the command bar , but when I want to give it a value only the first letter of wat I'm typing is shown. When I use a second macro that works in combination with this one I can see that the values I give the variables are correct so the macro works but I can't see what I'm doing.
Niels
8 REPLIES 8
Message 2 of 9
Charles_Shade
Is the Command Window just too small perhaps?
Message 3 of 9
in reply to: Charles_Shade
No, I'm using the new Style commandbar. Tried the old commandbar with 3 rows in the display and still don't see the variablenames.
the macro runs on ten computers and on all of them the variables names aren't visible.
Niels
Message 4 of 9
pendean
if you hit F2 key to get the text screen, do you see what is missing?
Message 5 of 9
in reply to: pendean
No I don't see the variables
I try to explain what is happning:
-I click the button with the macro (the commandbar is blank, nomatter what I do (F2 , make it larger) it stays blank )
-then I type a number and give enter
-Now everything is visible ( before the enter I couldn't see what command was active)
-type in de value for the second variable. (only the first letter is shown, for the rest I can't see what I'm doing)
- enter
Niels
Message 6 of 9
bgingerich
A couple of screen shots would do wonders in helping to show/explain what's happening
A picture is better than a thousand words.
(if ("mysolution"=answer) then (click "Accept As Solution"))
Brandon Gingerich
Message 7 of 9
pendean
in reply to: bgingerich
I think someone with ready access to LT2013 can test this without a screenshot, the description is pretty clear: I can't right now so I have no ability to do so.
If the isssue as described can be repeated, there will be no end-user fix as the problem is a core LT2013 inability to echo the macro in the text screen. It will need to be reported as a bug.
Message 8 of 9
drjohn
SWAG: MENUECHO perhaps?
Initial value: 0
Sets menu echo and prompt control bits.
The value is the sum of the following:
1
Suppresses echo of menu items (^P in a menu item toggles echoing)
2
Suppresses display of system prompts during menu
4
Disables ^P toggle of menu echoing
8
Displays input/output strings; debugging aid for DIESEL macros
Message 9 of 9
in reply to: drjohn
Tried the menuecho, no changes.
Can someone test this in LT2013?
Niels
”Boost
