AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Sending dwg drawings to another user
1 REPLY 1
djbeck
726 Views, 1 Reply
We are currently using autocad 2014 LT - new user
When we create work and need to send to Client (as a dwg file), when they open the file nothing is there?
Q. Can anyone advise what we are doing wrong?
1 REPLY 1
hwalker
in reply to: djbeck
Welcome to the Forums
Use the command ETRANSMIT (you will find it at the FILE menu). This will place every file which is needed to open your drawing into a zip file, which you can then send to the client.
One of the problems with sending drawings is sometimes you might have xref'd a drawing into a layout.
If you just then send the drawing the xref is not sent as it is a separate file and not actually in the main drawing.
Howard Walker
Left Handed and Proud
”Boost
