I'm a newbie here that needs your help on Macro's. Do you have a macro or Diesel command that would select all text or dimensions in a drawing and delete it automatically. I've seen an LISP command, but I know from a fact that it does not work on LT. By the way, I'm using Autocad LT 2014. Thanks in advance.
Check out Quick Select (QSELECT) -- it can grab all text or all dimensions, then you can just press Delete.
Selecting an object and choosing "Select Similar" from the right-click menu might be an option too, depending on how many different styles you have.
Set SELECTSIMILARMODE to 64
Click on one Dim to highlight, Right click, choose Select All, Erase or Delete
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
