AutoCAD LT Forum
scale not quite right when printed out
3 REPLIES 3
NickWelvent
345 Views, 3 Replies
Hi
I am having a problem with my scale when printed out. For Example
i set the scale of the layout to 1:1
The page set up manager is set to a4 210 * 297mm
The scale is set to 1mm = 1 unit
i draw a 100mm line and print it
when i measure the line 97.5mm on the paper.
It is always wrong when i use other scales 1:5 etc.
Can anyone help me?
Nick
Tags (2)
3 REPLIES 3
Irish2
in reply to: NickWelvent
Nick,
It sounds like your issue is with your printer setup. Are you printing to pdf first? If so check that you don't have it as "fit to page" or some such thing. There are a few other similar types of check boxes to look at. Bottom line though is that your issue is with your printer.
NickWelvent
in reply to: Irish2
Thanks for the reply
i found a calibrate printer option and went through that, and it seems to be spot on now.
well i guess as accurate as my eyes/ruler and epson printer can be
thanks again
Charles_Shade
Please mark you own solution as Accept as Solution so that others with a similar query may find this answer.
”Boost
