How do I default save in an older format than 2013? I have a system that will not work with any dwg file other than 2004 format.
Solved by sthompson1021. Go to Solution.
But be aware that other issues may crop up when content created in LT 2013 is saved to an older version.
Try a few and see if they work as you expect.
If not post back with the issues and there may be a fix other than not using the new program content.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
