AutoCAD LT 2014 will occasionally display an error message when I attempt to manually save (QSAVE) a drawing. Any suggestions?
Steve
There have been a number of people reporting this and has happened to me on several occasions.
Most recently the error has been the the File is read only and therefore cannot be saved.
Clicking on Save again after this occurs usually completes an ordinary Save.
Not sure if this is a LT 2014 general error that will be corrected with the first SP or just a general AutoCAD ongoing error.
I have never had this happen before; only now with the LT 2014 install.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Exact same save procedure that I was doing. Save to Desktop then back to the original folder.
This only happened to me that the file was being removed from the Original folder.
Have you tried a hard re-boot or as this been ongoing?
http://forums.autodesk.com/t5/AutoCAD-LT/File-Save-LT-2014/m-p/3905955/highlight/true#M113599
Regarding the location of my file, I am saving the file to "Local Disk (C:).
Other than the length of the file path (i.e., fairly large number of
characters), I do not think there is anything unusual about the location. I
have worked with AutoCAD and AutoCAD LT for a long time and I have never had
this error to my knowledge.
You did know that there is a 255 character limit on path/ filenames ... right?
DJ
I finally have a screen shot of the error message. I hope this will help shed some light on the problem
Steve
I also made a screen shot of the files created when the save error occurs. The only file originally at this location other than the pdf folder was the *.bak file. I have never noticed anything like this before.
Agreed but LT 2014 is the first time in this particular save error has ever happened to me.
I disabled Autodesk 360 and have not had the problem since. It appears that Autodesk 360 is at the root of the problem.
The 360 team is catching a lot of flack on many fronts.
