You can do this a few ways... Assuming that your PICKFIRST is set to 1 and
the Text/MText is all Middle or Middle-Center justified then this is fairly
easy.
Have the Properties Dialog box open (CTRL+1)
Select the Text/MText (or select all, and use the little pulldown at the top
to only select the Text objects) and then change the rotation to 180.
Tracy W. Lincoln
Autodesk Discussion Group Facilitator
http://www.autodesk.com/discussion-announcements
"David Charles"
wrote in message
news:64323.1081738006476.JavaMail.jive@jiveforum2.autodesk.com...
> I have a drawing with many structures and each labeled with a separate
MTEXT. I rotated the drawing, and of course, all the MTEXTs ended up upside
down. Now I'd like to rotate them all 180 deg around each MTEXT's center.
Is there a way to rotate multiple objects - each being rotated around it own
center?
> Thanks.
