AutoCAD LT Forum
Rotating In The Z-Axis
2 REPLIES 2
2607 Views, 2 Replies
I have an object that I would like to rotate 90 degrees in the Z axis. Is this possible in AutoCAD LT98? How can I do so?
2 REPLIES 2
AutoCAD LT will always rotate around the current Z axis. The trick is
to use the UCS command and place the Z axis in such a way that you get
the rotation you want.
Dietmar Rudolph
President, CR/LF GmbH, http://www.crlf.de
Vice-President Europe, CADLock, Inc. http://www.cadlock.com
Member of the Autodesk Discussion Forum Moderator Program
Author, "Mastering AutoCAD 2000 Objects", http://www.crlf.de/Verlag/PublishingServices.html
Rotate the UCS about the X axis 90o first. Then use rotate.
”Boost
