I have a drawing where it was dimensioned with horizontal alignment. The problem is that the viewport in the layout is rotated 90 degrees and I want the dimensions to be plan readable. I tried rotating the UCS in the model space to align with the layout, but the dimension numbers did not rotate after I tried to update them. I only have 20 and can redo them quick enough, but it seems like there ought be an easier way.
Brad
LT 2011, XP Pro SP 3
Can you rotate the text with the properties pallette? Under the text section about 13 items down is a text rotation option.
Duh! I was looking right at it, but tried the one right about it about view direction. I think I need a vacation, but with this economy I will be visiting my backyard.
Brad
