Can you elaborate?
Do you need to number them?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Yes. I do fire alarm system layouts and would like to be able to insert the room names and numbers as I see on other architectural drawings
Are you the one drawing the Architectural drawings?
Usually the architect use separate layers for Room ID and name, if theres no room ID's or room names present in the drawing then it's on the architect.
If you like to do it yourself then... use normal Mtexts?
I work in pretty much the same business, I do security alarms and including firealarms. Usually we get an Architectural drawing from our customer or directly from the architect and we attach it as an Xref. The state of the Architectural drawing is up to the Architect, we don't modify it more then turning off/on layers.
(EU - Sweden)
Thanks for the info Adam. I do on occasion create the drawings, so I would like to be able to insert that information. I did not know if AutoCAD LT had that capability or if it is only on full AutoCAD.
I am thinking make yourself a block with attribute tags for room name and number. when you insert it you will be prompted for each of the two values.
This is a Macro that can be placed on two Buttons and provide for a numbering scheme.
-To provide a numbering scheme as in Rooms. Text height must be zero:
-Put this on one button:
^C^C_setenv;StartWithNumber;\_setenv;TextInFront;\
-Put this on a second button: (I added the Textstyle set portion S;Standard;)
*^C^C_text;S;Standard;\;;$M=$(getenv,textinfront)" "$(getenv,startwithnumber);setenv;startwithnumber;$(+,1,$(getenv,startwithnumber));^M;
Bob's suggestion may be more versatile depending on how you use it.
Imo using a block with attributes for Room ID and name would only be necessary if you plan on extracting that information out to excel or likewise, Mtexts are usually more open and easy to use.
Check this one out.
I got tired of thinking and typing. I am amazed at how many names I have come up with.
Looks pretty smooth, but how come everytime I select a block property tablet grip my Autocad crashes -.-
Gonna have to look into that one tomorrow..
I have mine in a block that has a rectangular border with a dynamic stretch and a wipeout. It even stretches an associated hatch for that professional 3D effect
