AutoCAD LT Forum
Welcome to Autodeskā€™s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Showing results forĀ
Did you mean:Ā
Ribbon Combo Box display size
3 REPLIES 3
c.dufrene
663 Views, 3 Replies
I'd like to understand to logic behind code "NaN" which controls the size of a combo box.
I found 2 of those combo boxes with the same value but the onscreen size is different...
But perhaps you have another way for me to have dim's style in my ribbon ?
Regards.
3 REPLIES 3
bgingerich
in reply to: c.dufrene
I'm not sure what the "NaN" is for, but if you are wanting to make the box smaller play around with different numbers instead of "NaN."  (e.g. 150)  Those spaces are for the width of the box in pixels.
ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€
Brandon Gingerich
c.dufrene
in reply to: bgingerich
Great ! you nailed it
pendean
NaN: Not a Number, it allows the CUI to resize as it sees fit without you entering a number (usually too wide I found).
ā€Boost
