Not a feature of AutoCAD, or LT, out of the box: you might be able to
automate the process in full AutoCAD, but LT is not equipped with that level
of programming where the solution can be practical.
Dean Saadallah
www.pendean.com
"Brad Story" wrote in message
news:BB490F18300EBD29B8271C59BE9D130E@in.WebX.maYIadrTaRb...
> I want to create a block place an attribute in it. I also want to "copy"
> this attribute to several different locations in the same block. Then
when
> I insert the block, I want to be able to enter the attribute value and it
be
> inserted to all of the different locations. However, if I use the
standard
> COPY function when creating the block to copy the attributes to different
> locations, then when I insert the block I have to type the value for each
> time I copied it. So is there a way to copy an attribute in a block so
that
> when it is inserted, you just have to enter the data once?
> Sincerely,
> Brad Story
> Purchase Engineering
> dbstory@bellsouth.net
> "Do or Do not, There is no try" -- Master Yoda
