AutoCAD LT Forum
Restore from bak file
15 REPLIES 15
Message 1 of 16
TatumGressette1814
32754 Views, 15 Replies
I have renamed a .bak file with a new name and changed the .bak to a .dwg extension. File type listed in Explorer is not changing from bak, nor will renamed file open.
15 REPLIES 15
Message 2 of 16
in reply to: TatumGressette1814
You need to turn on file extensions in Windows Explorer in order to see an
change them: they are by default hidden.
Windows Explorer>Tools>Folder Options, look for a list in one of the tabs or
areas. Tap Windows Help if needed.
Dean Saadallah
http://LTisACAD.blogspot.com
Message 3 of 16
Dear Dean Thank you for helping. The file was compounded by a .bak.dwg extension. I have it open but all I see is a small dot. I have tried everything I know to scale it up. I have zoomed extents, erased the screen after removing the dot and it still will not scale up. Plse help a little more. This was the same problem with the original dwg file so we went to a bak to restore it. Thanks Tatum
Message 4 of 16
Tatumgressette1814,
Have you tried looking in for the drawing in the location on your computer where it save all 'Automatic Saves', which is general in your C:\documents and settings\garsp\local settings\temp. Note the 'garsp' is my username yours will be different. You can also find this link under the tool menu then options, select the files tab, then under the 'Automatic Save File Location' you will find a path copy and paste that into the address bar then just scroll through you should find .dwg, .bak files in there.
Gareth
______________________________________________________________
Applications Engineer @ www.cadline.co.uk
http://www.cadlinecommunity.co.uk/Blogs/garethspencer/Default.aspx
http://becadsmart.blogspot.com/
Follow me on Twitter @GarethCadline
Message 5 of 16
Zoom>Window
>>>...This was the same problem with the original dwg file ...<<<
Your file is empty if that is true: dwg file size? Post it if you want.
Dean Saadallah
Message 6 of 16
Hope you can see the small dot. It is definitely there, like an over scaled image.
Message 7 of 16
zoom extents is all I did.
Dean Saadallah
Message 8 of 16
Go to 3d views then topview, same result
Edited by: bakdraft on Mar 10, 2010 1:17 PM Edited by: bakdraft on Mar 10, 2010 1:19 PM
Message 9 of 16
I did a Zoom > Extents and deleted 4-5 "dots" on the left of my screen and then a crossing deletion of a "dot(s)" on the right side. Another Zoom > Extents and got this. Might be luck that this drawing was not one of the "dots" I deleted.
Is this the missing drawing?
These "dots" were about a Parsec away from the drawing. 😉
Regards, Charles Shade
Message 10 of 16
...why, that's only 1/12th of the record for the Kessel run. piece of cake...;-)
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! 🙂
Message 11 of 16
You're old for that reference. Haha
Message 12 of 16
Got it guys! TX a million for the help. Thanks to all for taking the hex off the dwg. My computer tried to open 3 times by using LT2004 and couldn't do it-then for some reason on the 4th attempt it (on its own) used our seat of LT2009 and it opened right up. I could have sworn I used both 04 & 09 in trying to open it before. Thanks again!
Tatum Gressette
Message 13 of 16
Eh? Type into my good ear...
Message 14 of 16
help me, i want to open
Message 15 of 16
prasath_26
in reply to: prasath_26
Message 16 of 16
pendean
You need to turn on file extensions in Windows Explorer in order to see and change them from BAK to DWG so you can open the file: they are by default hidden.
Windows Explorer>Tools>Folder Options, look for a list in one of the tabs or areas. Tap Windows Help if needed.
”Boost
