Hi everyone, I am having an issue with importing a layer state. When I import a layer state it changes all my line types to continuous, When I open the .las file in notepad They are all there and correct is there something that goes on in the import or is there a setting that I’m missing?
Neal
I am having the same issue and I have done this before without any issues in earlier versions. I am using 2014 now.
What I am doing is exporting revit drawings into autocad. I then import my layer state and then pops up this message. I click ok and then close. I check my layers and they are all there but colors are missing. I did keep trying it and it magically worked but not sure what it was causing that issue. If you do know anyway I should specifically doing the process It would help a ton and greatly appreciated! 🙂
