AutoCAD LT Forum
Resizing Objects
1 REPLY 1
Deknaster
469 Views, 1 Reply
Resizing Objects
AutoCad 2012LT was working just fine. But all of a sudden the dynamic blocks will not resize as they once did. For example, on a block that I had a stretch action I could click on the arrow and it would show the current value. I could then enter a new vlalue and it would resize. It will no longer do this but it will let me stretch it by dragging the mouse. I have also noted that if I click on a line and the hoover over the grip it no longer shows the length! Can this be related to a bad (or going bad) graphics card?
1 REPLY 1
AcadAdamLT
in reply to: Deknaster
Press "f12"
Sounds like you've turned off Dynamic Input.
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
”Boost
