I am attempting to install AutoCad LT 2000i on Windows 7 64-bit but am running in to problems. I'm fairly confident this can be done because I have another computer running Windows 7 64-bit with AutoCad LT 2000i running using Win XP SP3 compatibility mode.
The box and disc sleeve say the product is AutoCad LT 2000i but the actual disc says AutoCad 2000. Once AutoCad is installed (it will install but not run and gives errors whenever you try to run it), the icon for AutoCad is different than on the other Win7 machine. I am wondering if I am using the wrong disc? I cannot be certain because another person installed AutoCad LT 2000i previously is no longer available.
Can I get replacement media for AutoCad LT 2000i? Where can this be done?
Solved by bradellc. Go to Solution.
DarrenP
