While great macros, they do not capture the deleted block's scale or
rotation, a key requirement by the OP.
To the OP, LT has no such programming ability as I noted in my first reply.
If you want such ability, you will need to spend another +$400 per LT seat
with a 3rd party developer (not me), then learn how to program or find a
freebie for full AutoCAD that will do what you seek.
HWALKER suggest using INSERT command and the naming function of
OLDBLOCKNAME=NEWBLOCKNAME, which works only if you are replacing different
blocks in your file. If you only use one block for all the locations, your
place holder as you note, that will not work either.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
