BreeseCAD,
Have you tried the solutions in the online Knowledge Base
http://support01.autodesk.com/KnowledgeBase.asp? Also this has been seen
when using apostrophes in the file name or directory but has been corrected
in the currently available SP2 for AutoCAD LT 2000i.
Other Today assistance:
Today System Diagnostics web page http://pointa.autodesk.com/TodayError.asp
Upon entering the diagnostics page it will ask you to accept loading of an
OCX file (needed). If this does not work you can also run RepairToday with
AutoCAD not running. RepairToday.exe is located for download online at
http://betaprograms.autodesk.com/files/repairtoday.exe or it can be located
on an installed AutoCAD LT 2000i at \AutoCAD LT2000i\WebDepot\ErrorHandler\.
Run it in aggressive mode. Please note you must launch AutoCAD after running
the RepairToday application and going to the diagnostic web page.
Sincerely,
Shaan Hurley
Autodesk Beta Programs
"BreeseCAD" wrote in message
news:ef634dd.-1@WebX.SaUCah8kaAW...
> I have to "Repair Toaday" every other day. Actually almost everyday. What
did I do wrong? Did I miss something in setup?
